cloudy
| posted on 28/12/08 at 05:47 PM |
Rally Design Mount code for Rear willwoods?
My wilwood calipers sit too far away from the center of disc, only scrubbing half the pads.
Can anyone check their code on the rally design mounts for sierra rear end? Mine are BK67
I got the discs with the calipers...
[Edited on 28/12/08 by cloudy]
www.warnercars.com
ghostrain
| posted on 28/12/08 at 06:54 PM |
Are your wishbones based upon a disc braked Sierra ,I think the Rally Design kit is intended for a drum brake Sierra donor,this has been reported on
previous posts
cloudy
| posted on 28/12/08 at 11:20 PM |
It was specced as being for a disc axle, which it's fitted to - will be a bit miffed if not as they told me it fits!
James
www.warnercars.com
AdamR
| posted on 29/12/08 at 12:21 AM |
Do you have hub carriers from a Sierra Cosworth? Not 100% on this, but I think these have the caliper mounts further out to allow for bigger discs,
hence could cause what you're describing.
Do let us know either way as I'm planning to fit a set of rear Wilwoods on Cossie hub carriers.
cloudy
| posted on 29/12/08 at 02:16 AM |
I'm not 100% sure they were now, I bought the axle complete 2 odd years ago - it's entirely possible...
James
www.warnercars.com
cloudy
| posted on 29/12/08 at 02:26 AM |
From what I can see cosworth had 273mm rear discs, over 253mm standard discs...
So either I need to find some light 273 dia rear discs or find a pair of standard size hubs (assuming the bearing assembly is the same size?) anyone
have any more info?
James
www.warnercars.com
