Author: Subject: Bike Powered Mini
Omni
posted on 3/1/09 at 08:45 PM Reply With Quote
Bike Powered Mini
Hi All,
Well I have brought a Mini and decided that a Bike Powered Mini is more for me.
Now my question is if I convert it to rear wheel drive (front engine) do I have to do an SVA? Will I be able to keep the plate if I make custom front and rear sub frames? (I really can't remember the point system).
O
Stuart_B
posted on 3/1/09 at 08:51 PM Reply With Quote
hi Omni, there is a smillar topic about it here,
hope this helps
stuart
[Edited on 3/1/09 by Stuart_B]
Omni
posted on 3/1/09 at 09:00 PM Reply With Quote
Hi Stuart
Cheers mate, but it doesn't really answer my question. I am not re-shelling it I am just cutting a tunnel and making custom front a rear sub frames, plus different hubs and a different diff, and brakes! lol. (not much )
O
Stuart_B
posted on 3/1/09 at 09:07 PM Reply With Quote
i, know it is not the same, but that is all i could find which has been smilar to what i have been looking for.
well i would have throught as you are not changing the chassis or body work, you would not need to sva it, but then to change the log book, it might be to much to change.
unless you do it in stages such as say it is rwd one month and change the engine no the next, so it does not pull to much attetion to it.
as it says a bit of a grey area.but there must be somebody out there how knows the answer.
p.s. and you are changing the drive and engine.lol
once i get a mini, i am make a custom front subframe, so you might be getting a few u2u sent your way.lol
stuart
Omni
posted on 3/1/09 at 09:14 PM Reply With Quote
Hehe. Cheers mate. Now orries on the PM's I plan to do a full build write up
Here's hoping someone can help with my questions I think a call to the DVLA or a SVA center might be in order
O
P.S. I know MAC 1 did one and that is still on a F Plate!
Stuart_B
posted on 3/1/09 at 09:18 PM Reply With Quote
i have looked at z cars online and a few off there cars and they seemed to be on the orginal number plates.
stuart
mr henderson
posted on 3/1/09 at 09:23 PM Reply With Quote
stuart
They could be age related plates, though
will121
posted on 3/1/09 at 09:37 PM Reply With Quote
good bit in this months PPC mag to maintain origional identity and avoid SVA need 8 points or higher, from: 5 for origional body shell, 2 for suspension, 2 for axles (not one for front and one for rear all standard or no points), 2 for transmission 2 for steering assembly and 1 for engine. in this account and from reading artical a motorbike rear wheel drive mini may be difficult as i read it will get 5 for shell and 2 for stearing and thats it
[Edited on 3/1/09 by will121]
GBaggott
posted on 3/1/09 at 09:55 PM Reply With Quote
Im just collecting the parts together for a be Minivan so its all useful information for me thanks.
Cheers for that info will, looks like ill be needing an sva.
GregSL75
posted on 3/1/09 at 10:28 PM Reply With Quote
The Z-Cars owner himself says SVA is required, but plenty don't bother.
I guess removing half the floor doesn't count as original 'unmodified' chassis
To be fair it is a reasonably radical mod converting to RWD. I guess you could ring your local SVA center and ask their opinion.
2.0 XE on GSXR TBs and Megasquirt
bigrich
posted on 3/1/09 at 10:30 PM Reply With Quote
The Mac#1 mini was built by Nick Mossop (shogun969) on here
It uses an early ZX9R engine under the bonnet and a sierra diff in the rear.
Mac#1 supplied the engine cradle and rear chassis sections, wishbones etc, The rest of the work was all done by Nick.Image deleted by owner
GregSL75
posted on 3/1/09 at 10:34 PM Reply With Quote
The original unmodified chassis or unaltered bodyshell (i.e. body and chassis as one unit - monocoque); or a new chassis or monocoque bodyshell of the same specification as the original supported by evidence from the dealer or manufacturer (e.g. receipt).
Link
There's a kitcar magazine guide somewhere on the web (i saw the link on here IIRC) that says they changed the wording to 'unaltered' monocoque to stop some kits using just the donor floorpan etc.
EDIT
[Edited on 3/1/09 by GregSL75]
will121
posted on 3/1/09 at 10:44 PM Reply With Quote
was really interested in the MAC1 mini seemed to have the best balanced lay out but never been produced in kit format as far as im aware?
Omni
posted on 3/1/09 at 10:59 PM Reply With Quote
Yeah this Mini is what has made me want to do mine. So how did he keep the Reg????
O
bigrich
posted on 3/1/09 at 11:06 PM Reply With Quote
I suppose as it still is a mini, it has been treat as a modification albeit a big one rather than a conversion so has'nt been subject to SVA just an MOT and a change of engine size and No on the V5, but thats just a guess. Maybe a u2u to Nick may answer any questions
Omni
posted on 3/1/09 at 11:23 PM Reply With Quote
Well I have sent him a message so hopefully he will get it Cheers Rich.
FINGERS CROSSED!!!!!
O
[Edited on 3/1/09 by Omni]
