Author: Subject: metalastic mounting bushes
alistairolsen
posted on 5/1/09 at 10:03 AM Reply With Quote
I have so far got land rover engine mounting buhes for the engine, and polybushes for the suspension,but I really need some small metalastic bushes for mounting the diff etc.
Can anyone advise me on what oe stuffI might find a motorfactors supllying cheap?
procomp
posted on 5/1/09 at 10:15 AM Reply With Quote
Hi
Try looking for Triumph items as used by westfield for suspension. There should be a couple of sizes available in the Triumph range.
Cheers Matt
davred
posted on 5/1/09 at 03:01 PM Reply With Quote
metalastic bushes
qh part no y976 hillman avenger t.c.a inner should do the job hth david
alistairolsen
posted on 6/1/09 at 08:39 PM Reply With Quote
ok,went to the motorfactors today:
Triumph bushes are discontinued by quinton hazel, andyone got any good suppliers?
Hillman ones were 1.32, but they dont have an outer metal casing, just an inner tube and rubber. Also the bore is too small to be useful for diff mounting really
Any other suggestions?
cliftyhanger
posted on 7/1/09 at 01:46 PM Reply With Quote
What sort of size bushes. I have some triumphs, and all sorts of odds and ends. Give me the size and description, and I can have a look?
Clive
alistairolsen
posted on 7/1/09 at 02:14 PM Reply With Quote
12mm bore, metal inner and outer, rubber inbetween. Enough to remove vibration from a diff mounting but not so much it wobbles around. Ive been told there is something suitable in the suspension of some peugeot model.
