Daddylonglegs
posted on 6/1/09 at 12:39 PM |
Axle Breather
I have a 52" live axle (Atlas or English - still not sure which ).
Somehow, in the move from the barn where it was stored to the garage I have managed to knock the breather off!
It looks like it is a push fit into the casing. My question is, can I get a replacement, or do I need to buy something like a Landrover one and tap
the hole to suit?
Cheers.
JB
posted on 6/1/09 at 01:49 PM |
This has been asked for before and I don't recall anyone able to find a source for them - other than taking off another axle.
I fitted one from a Series Landrover - it is a little bit smaller but a bit of araldite cured that.
r1_pete
posted on 6/1/09 at 01:53 PM |
Part number 3 here should do you, its a 3/8 unf screw in plastic job, but
should easily modify to push in.
Daddylonglegs
posted on 6/1/09 at 02:08 PM |
Cheers chaps
blakep82
posted on 6/1/09 at 06:45 PM |
if its the one in your archive, definitely not an atlas
here's my atlas
of course, with the tubes cut off
[Edited on 6/1/09 by blakep82]
________________________
Daddylonglegs
posted on 6/1/09 at 10:26 PM |
Yep, this is the one I'm using. It's 52" flange to flange.
??? Axle 3
blakep82
posted on 6/1/09 at 10:29 PM |
looks english to me
is it definitely off a ford? (i think there's some other type that look the same)
if its off a ford, its an english
Daddylonglegs
posted on 6/1/09 at 10:53 PM |
Yup. I was told it was off a ford. Actually picked up 2, one 48" (Escort) and this one, but haven't got the Escort one now.
So I think it's safe to say it's an English then.
Chose this one because of the extra 4" width but causing me a headache in trying to design the front bones to cater for the extra width!
Trying to keep the same ratio of length to spacing between bushes to maintain the same bending load on braking, but it's making the mount points
about 3" further apart. Damn nightmare
blakep82
posted on 6/1/09 at 11:23 PM |
well, it definitely looks like an english (100,000% definitely not an atlas) but there are a few other types that look identical to the english, but
aren't. someone on here had one in a racing car chassis, i forget what it was from though. austin or something
edit:
Tegwin, ask him what his was from. here's his in the yellow car. looks VERY similar.
Daddylonglegs
posted on 7/1/09 at 08:41 AM |
Knowing my luck it's probably a one-of from a prototype space shuttle or something!
