Z20let Corsa
| posted on 8/1/09 at 09:24 PM |
sierra driveshaft worries.
well ive just refurbed the driveshafts and put them together once finished and one is longer than the other. im slightly worried about this as im
pretty sure the diff is to be mounted in the middle of the chassis!!!! Diff looks symetrical too. anyone else experienced this?? the diff and shafts
etc were stripped off a xr4 axle that i purchased.
scotlad
| posted on 8/1/09 at 09:27 PM |
Dont panic- one is meant to be longer than the other!!! Someone will be on shortly to say which one goes where as i cant remember!!!
Wonderous is our great blue ship that sails around the mighty sun, and joy to everyone that rides along!
Blackbird Rush
| posted on 8/1/09 at 09:28 PM |
On some sierra's the drive shafts are indeed different lengths..... dont worry...
alistairolsen
| posted on 8/1/09 at 09:36 PM |
just look at the diff, IIRC its assymetric by a little more than an inch. the input flange doesnt sit int he middle of the casing?
Z20let Corsa
| posted on 8/1/09 at 09:39 PM |
ahhhh i never looked at that. i just looked at how much each side sticks out, not the input shaft!! i can work out which shaft goes on which side by
that and by which way the threads go on the hub nuts. cheers lads.
locost +4 v8 in progress.
Thinking about it
From memory the short one is the near side.
Make sure you put the right hub end on the right shaft as I seem to remember it was a left hand thread on the nearside.
Or is my memory failing me and I'm thinking of something else. More help will be along no doubt.
clairetoo
| posted on 8/1/09 at 09:56 PM |
What - help for your failing memory ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
cd.thomson
| posted on 8/1/09 at 09:57 PM |
As you look from the back to the front of the car the shorter shaft is on the left hand side.
Thinking about it
| posted on 8/1/09 at 09:58 PM |
If you have the help I will take it.
