Author: Subject: tracking settings.
Danozeman
posted on 16/1/09 at 09:58 PM Reply With Quote
tracking settings.
Is the a recommended toe and camber setting for a locost type car? Straight ahead??
Need to set mine up.
[Edited on 16/1/09 by Danozeman]
Dan
posted on 16/1/09 at 10:01 PM Reply With Quote
Don't know about recommended Dan, but I set mine to 1mm toe in . Seems to be OK handles fine with no abnormal tyre wear. If you need them I have some steering turn plates , camber and castor gauges and corner weight scales
Danozeman
posted on 16/1/09 at 10:19 PM Reply With Quote
Thanks for that mel, iv got all the alignment stuff at work. the weight gauges would be handy though.
Dan
posted on 17/1/09 at 08:55 AM Reply With Quote
Let me know when you want them.
Danozeman
posted on 17/1/09 at 09:11 AM Reply With Quote
Ok mate. Maybe ill pop over and show you the car and you can show me how to use them
Dan
posted on 17/1/09 at 09:47 AM Reply With Quote
Will be around this morning until about 1pm . Going to be away from then until tomorrow afternoon.If I'm not at home will be over the garage
posted on 17/1/09 at 04:02 PM Reply With Quote
Dan,
I set mine to straight ahead - a little toe-in is fine, but toe-out can make it very twitchy when you're trying to go in a straight line!
Evo,s 7SE
posted on 18/1/09 at 10:30 PM Reply With Quote
front end
set it to parallel
Evo,s 7SE
front end
set it to parallel
Evo,s 7SE
front end
set it to parallel
Evo,s 7SE
front end
set it to parallel
Evo,s 7SE
posted on 18/1/09 at 10:31 PM Reply With Quote
front end
set it to parallel
Evo,s 7SE
front end
set it to parallel
