Neil P
| posted on 20/1/09 at 09:28 AM |
Maxi balljoints
I've managed to 'mislay' the nuts belonging to my balljoints.
Can anyone tell me what thread they are, please?
Neil
carlknight1982
| posted on 20/1/09 at 02:43 PM |
im in the same boat here
| posted on 20/1/09 at 03:06 PM |
Have you tried measuring the width of the threaded bit and measuring the teeth density (ie how many inches / mm per teeth). You should be able to then
look them up in an engineering book / website.
Trad way of working out teeth density is measure how many threads there are, measure how long the threaded section is and divide one by the other...
| posted on 20/1/09 at 04:02 PM |
Maxi ball joints (as used for the lower front ball joint on MK and others) have 2 off plain holes in the the mounting plate for M8 bolts and nuts.
Like this....
Do you mean the Transit drag links for the upper front ball joint?
[Edited on 20/1/09 by nick205]
carlknight1982
| posted on 20/1/09 at 04:46 PM |
lower bottom ball joints
| posted on 20/1/09 at 06:40 PM |
I suspect the OP means the Nylock nut in your picture. It's usualy quite a fine thread on most of them, but I suspect it's not
standardised as I have seen different manufacturers parts use different threads.
| posted on 20/1/09 at 09:09 PM |
....aaahhhhh! I see
Sorry...can't help in that case.
