Author: Subject: leccy reverse
adam1985
posted on 20/1/09 at 07:43 PM Reply With Quote
leccy reverse
hi all im just trying to find out what sort of thing people have done for reverse.
I know people have used a starter moter on some sort of slide action to engage a cog in between the diff and prop.
But first question what cog have you used for this and how have you fixed it to the diff.
also what starter moter have people used
russbost
posted on 20/1/09 at 07:47 PM Reply With Quote
I use the Toyota MR2 Mk1 starter as it comes "free" with the donor vehicle, I also use the Toyota diff, same reason. I have a machine shop cut a gear for the starter pinion to mesh correctly with.
Pics in my archive. HTH
adam1985
posted on 20/1/09 at 07:52 PM Reply With Quote
one thing ive just thought looking at that does the cog have to be balanced or anything or will it not be spinning that fast on the front part of the diff i dont want it flying off or explodeing much like a unbalanced flywheel can
looks like a good setup you have there does it work well ??
[Edited on 20/1/09 by adam1985]
russbost
posted on 20/1/09 at 10:32 PM Reply With Quote
It's only ever spinning at around 1/3rd drive gear rpm which is already reduced on bike gearboxes by a factor of around 1.5 & it's very light being alloy - I've certainly never heard of a bike sprocket causing a problem by being out of balance & rotational speeds would be very similar.
The system has only had bench testing so far as the first of the bike engined Furores has yet to hit the road (unless you count my original twin engined one, but that didn't have reverse) from what I've seen so far have no reason to expect it to cause problems, but it's only intended to pass IVA & to get you out of an awkward situation - I wouldn't be going autotesting with it!
