Author: Subject: GAZ shock mounting eye size?
cloudy
posted on 22/1/09 at 11:05 AM Reply With Quote
I don't believe these are metric - M12 is a pretty good fit, anyone know the correct size? (GAZ GP shocks)
James
[Edited on 22/1/09 by cloudy]
www.warnercars.com
prawnabie
posted on 22/1/09 at 11:07 AM Reply With Quote
1/2" (12.7mm)
MikeCapon
If they're not metric and 12mm is a pretty good fit then they must be half inch ie 12.7mm
cloudy
posted on 22/1/09 at 11:25 AM Reply With Quote
Thanks - anywhere sensible to buy these? They are about £5 a pair in stainless on ebay!
www.warnercars.com
grassracer
posted on 22/1/09 at 11:32 AM Reply With Quote
Try Namrick.....google search will pull it up, good online shop too.
cloudy
posted on 22/1/09 at 11:48 AM Reply With Quote
Ah, great looks good - do stainless bolts have the same "8.8" ratings available for the SVA man?
www.warnercars.com
posted on 22/1/09 at 11:54 AM Reply With Quote
Stainless bolts have a different rating, you won't find any with 8.8 marked on them.
IIRC A2-80 is the closest stainless grade to 8.8, but I don't know if this is acceptable for SVA.
MikeCapon
posted on 22/1/09 at 02:54 PM Reply With Quote
To the best of mk knowledge A4 is the strongest of the commonly available stainless bolt materials. If the SVA calls for 8.8 then you'll need steel bolts. Decent zinc plate (BZP) is reasonably corrosion resistant and does not look too bad.
