Miks15
| posted on 23/1/09 at 10:45 PM |
Rear uprights
Can you please post some pictures of your rear uprights. Im trying to avoid anything using a tube down the center. Has anyone got any examples using
just plate steel.
Mikkel
Fred W B
| posted on 23/1/09 at 10:56 PM |
See a bit HERE
Fred W B
Chippy
| posted on 23/1/09 at 11:18 PM |
No tube used on mine, but i did use the Sierra ABS hub carriers, which was a bit of overkill. May give you an idea though. Cheers Ray
  Plus one I made earlier
Miks15
| posted on 23/1/09 at 11:23 PM |
thats more or less the sort of things im after, what thickness plate did you use?
Mikkel
Chippy
| posted on 23/1/09 at 11:27 PM |
The rusty bits laying on the floor are all 3mm rolled plate. The hub mounting could be either the one from the Sierra suitably modded, or a piece of 8
or 10 mm steel. Cheers Ray
dogwood
| posted on 24/1/09 at 09:19 AM |
Try this link from the
Haynes Roadster Forum
http://www.haynes.co.uk/forums/showthread.php?t=1247
HTH David
FREE THE ROADSTER ONE…!!
fazerruss
| posted on 24/1/09 at 09:25 AM |
I made mine from 5mm steel plate. The dimensions are more or less the same as the avon but with a few refinements
Forum Code:
Forum Code:
Forum Code:
Forum Code:
[Edited on 24/1/09 by fazerruss]
"if assholes could fly this place would be an airport"
