mr henderson
posted on 25/1/09 at 08:16 PM |
Converting a Transit (or similar) into a 7 transporter
Anybody have any ideas, knowledge or opinions about this?
Looking at the price of trailers, it strikes me I would be just as well off with a transporter. Most of the existing ones are quite a bit bigger than
necessary, though, so it might be an idea to start with a flatbed vehicle of some kind and modify it to the purpose.
Maybe it could even be covered, which would be good as I am often moving unfinished cars, although that would make access for strapping purposes more
difficult.
All ideas welcome
John
blakep82
posted on 25/1/09 at 08:24 PM |
what about starting with a chassis cab like
this? two pieces of U channel bolted on the back, with some
U channel ramps would do the trick maybe?
though looking again, youd essentially have to build a frame on the back to support the U channel, basically build a trailer on the back...
[Edited on 25/1/09 by blakep82]
________________________
MkII
we've done a few of these at work ,youve got to get approach angles right because the bed is going to be higher than a trailer.the other thing
we've had to be carefull of is weight it would be all to easy to make a good strong job but no good if it was over legal weight with a fiesta on
its back. i appreciate the weight thing wont be so much of an issue if your going to carry mainley 7 type vehicles but this will make the angle of the
ramps more of a problem hth.m.
GregSL75
posted on 25/1/09 at 08:25 PM |
Ford Transit Forum is a good place to look.
That thread has about 3 or 4 builds on it.
Just beware that chopping the chassis and welding in an extra 2 foot almost certainly requires SVA regardless of what they say..
2.0 XE on GSXR TBs and Megasquirt
smart51
posted on 25/1/09 at 08:41 PM |
What if you made a bolt on 2ft extension and moved the lights and number plate back a bit?
aerosam
posted on 25/1/09 at 08:43 PM |
Just a thought, a trailer may be cheaper in the long run as it doesn't have to be taxed, insured mot'd etc.
Had enough of this dictatorship known as LCB. Gone elsewhere, not coming back. Kiss my ass ChrisW.
GregSL75
posted on 25/1/09 at 08:45 PM |
I guess the reason they're welding in and lengthening the wheelbase is to keep the weight between the axles though.
mr henderson
posted on 25/1/09 at 09:18 PM |
Well, the thing is, I really only use my Volvo for moving cars or other heavy stuff, so if I had a transporter I wouldn't need the Volvo any
more(my wife has a car that can be used for shopping etc).
Interesting stuff so far on this forum, especially that Transit forum link, Greg
I think the ideal thing might be a Luton, if I could only find a way of getting a car up into it.
John
DIY Si
posted on 25/1/09 at 09:38 PM |
Would a long set of ramps, maybe even folding or 2 piece ramps be an acceptable way of getting cars in the back? It's how my dad gets exotic
cars in the back of his 17.5T truck at work. Maybe have the ramps on the truck either at an angle, or with some form of ram under the front edge to
allow them to tilt.
Sun Tzu, The Art of War
dinosaurjuice
posted on 25/1/09 at 09:39 PM |
how about like.......
THIS
sorry in advance for the stupid suggestion
lsdweb
posted on 25/1/09 at 10:55 PM |
I've toyed with this as I want to carry the car and tow the caravan (weight is th problem!)
What about a box van with 500kg tail lift with extensions - a 7 should fit inside. Nice and dry and pretty secure and OK for carrying part builts
too!
Wyn
MikeR
posted on 26/1/09 at 12:30 AM |
NS Dev has been looking at this - a standard transit won't fit a seven, i can't remember if a box does fit.
As for getting a tail lift ..... the Se7ens.net group used to have the old westfield 7.5 tonne, tail lift van/truck. Did them proud apart from the
high running costs and lower powered engine.
carpmart
posted on 26/1/09 at 01:16 PM |
This was my solution. I tow a caravan on the back with my race car inside!
You can't get enough width in a standard Transit or Sprinter or Iveco etc
I have some long ramps and a winch . The ramps are domed so its quite a level entry when the car crosses the threshold into the van.
I think its quite an elegant solution!
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=2Image089.jpg
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=2Image088.jpg
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
lsdweb
posted on 26/1/09 at 05:20 PM |
carpmart - I like!
Do you have any photos of the ramps etc.? What size engine does the van have and do you have any power / weight issues when towing? I won't
start asking you about your caravan as I know I'll get slammed on here! :-)
carpmart
posted on 26/1/09 at 09:50 PM |
quote: Originally posted by lsdweb
carpmart - I like!
The engine is the 311 with the 2.2 cdi engine so it 109 bhp stock which doesn't sound much but its a very torquey delivery and is
'adequate'. I have upped the power and torque with a 'dragon' piggy back fuel map which (allegedly) gives me around 155 bhp,
about the same as the 316 flagship Sprinter model. Even standard, I can leave it in 5th and it pulls fully loaded with the caravan on the back up any
motorway hill I have encountered!
Weight wise, its a 3.5 ton van and my race car has to weigh under 350kgs for the regs. I would imagine with welders, gennys, tyres, wheels, spare
engine etc etc I probably have an 800kgs payload, so the van is circa 3000kgs loaded. I then tow a caravan (Sterling Europa which I bought new in
200) which is 1275kgs empty so near on 1500kgs with the sundries one carries. This gives a total train weight of circa 4500kgs. This seems to work
fine and I get 300 odd miles to £60 of diesel. Actually, towing the caravan makes little difference to economy (performance) as the caravan sits in
the hole punched in the air by the van! I tend to tow at around 65 which seems to be just the right speed for the rig. I think the economy is pretty
good!
Sorry but I have no photo's of the ramps/winch!
All in all, I think its a pretty good solution!
'94 MX5 MK1, 1.8
lsdweb
posted on 26/1/09 at 10:19 PM |
Thanks!
Also got a Sterling Europa!
Time for a scan of eBay!
