Author: Subject: Diff ratio... for BEC
Major Stare
posted on 3/2/09 at 08:59 PM Reply With Quote
My Westfield has independant suspension and an alluminium diff with a Westfield stamp on it.
How do i work out/know what ratio it is?
Im fitting an R1 engine this month and would like to know.
Jon "FISH"
roadrunner
posted on 3/2/09 at 09:05 PM Reply With Quote
You could jack the back up do one revolution of you wheels and then count how many turns your prop does.
ReMan
posted on 3/2/09 at 09:08 PM Reply With Quote
Way to go^^^^^^^
Guinness
posted on 3/2/09 at 09:19 PM Reply With Quote
Bank manager gave you the loan then!?
Thank god the credit crunch is over!
Mike
adithorp
I'd say you want a 3.36 for a 7 with an R1. Anything higher and you'll run out of aero and any lower and you'll run out of revs. Final drive ratios vary depending on the year of the R1 though so check that as well.
My Fury R1 has a Freelander 3.21 and its a bit high geared off the line but with better aero it goes through 130mph as I change into fifth (on the track) pulling like a train so I'm pretty sure it'll hit pretty close to the projected 150+ in top.
adrian
http://jpsc.org.uk/forum/
a4gom
posted on 4/2/09 at 12:17 PM Reply With Quote
John, you may be lucky but I'd say you probably have a 3.89 like me, best you will get for our casing is 3.54
Perfect planning prevents pi$$ poor performance!
