joolsmi16
| posted on 4/2/09 at 02:33 PM |
1.9 id springs
Hi all, Iam having some trouble finding 1.9 id * 7inch 800 - 900lb spring
Any ideas tried the normal but 650lb is the highest.
Jools
Hammerhead
| posted on 4/2/09 at 02:35 PM |
pinto eh?
| posted on 4/2/09 at 02:37 PM |
quote: Originally posted by Hammerhead
pinto eh?
Sounds more like a twin Pinto engine set-up at those poundages
MikeCapon
| posted on 4/2/09 at 02:45 PM |
These certainly exist. I have used them before on 125 Aprilias. What on earth are you using them on? I could give you the details for my old spring
manufacturer who made these for me if you wish.
The other thing to watch out for with short high rate springs like these is that there is enough movement in the spring to avoid coil bind before the
shock itself is closed.
joolsmi16
| posted on 4/2/09 at 03:24 PM |
springs
Its a 3 wheeler with a single rear wheel at the rear got 600lb at the moment and it not enough.
If you have details of a spring manufacture that will be of help.
jools
joolsmi16
| posted on 4/2/09 at 03:29 PM |
springs
joolsmi16
| posted on 4/2/09 at 03:30 PM |
springs
.JPG)
pewe
| posted on 4/2/09 at 04:21 PM |
These guys were recommended on here recently. Look for the post as there's a name to drop in the conversation.
www.dfaulknersprings.co.uk/
Cheers, Pewe
g.gilo
| posted on 4/2/09 at 04:31 PM |
springs
hi
cant help with springs sorry, but would love more pics and a description please.
big 3 wheel fan went to see bilands bio and owen greenwoods mini in years past.
regards graham g.gilo@yahoo.co.uk
p.s. looks brill keep it up
mr henderson
| posted on 4/2/09 at 06:33 PM |
Is the current spring not stiff enough (too much up and down motion) or does it need to be a bit longer?
John
idl1975
| posted on 6/2/09 at 02:19 PM |
Can you not use a twin spring/twinshock setup?
Might actually be better than asking a damper to control that sort of spring rate, especially given that you aren't using a monoshock linkage
anyway (edit: ... and therefore have the disadvantages of dealing with swingarm movement associated with traditional twinshock setups).
Jools
[Edited on 6/2/09 by idl1975]
