Author: Subject: Poor running Zetec 2 litre
Scoobythedog
posted on 22/2/09 at 03:07 PM Reply With Quote
Just got the 2 litre zetec started and running, It jumps up to about 2000rpm and then drops to 500rpm, and sounds like its about to cut out, then jumps up a bit, but it won't settle . What is the likely cause of this ?
It also seem to spit out from the expansion tank overflow, I have the outlet of the expansion tank going into what I am convinced is the inlet of the heater pump, (manifold side of the engine) is this right ? or what is causing the spitting ? (its more noticable when the engine revs)
Scooby
big_wasa
posted on 22/2/09 at 03:10 PM Reply With Quote
A bit more info mate.
As for running poor what induction and ignition are you running ?
Scoobythedog
posted on 22/2/09 at 04:07 PM Reply With Quote
Its as it is straight out the mondeo it came from. Same ECU and ignition,
Scooby
piddy
posted on 22/2/09 at 06:02 PM Reply With Quote
What year was the Mondeo?
Was it fitted with a Lambda sensor and if yes, have you fitted one in your set up?
big_wasa
posted on 22/2/09 at 07:21 PM Reply With Quote
Thats what I thought.
so the engine is "hunting".
They do that as they are trying to run as lean as posible.
Once warmed up it will run closed loop on the lambada.
So is the lambada heating and working and the outher big thing to look for on these are air leaks on the manifold.
Have you blocked of the brake servo take off. There are also vac take offs for the egr and somthing elts I cant remember of the top of my head. Are you running the emisions stuff or have you dumped it ?
Scoobythedog
posted on 22/2/09 at 09:24 PM Reply With Quote
Yup, the lamba thing is the standard one, wired in as instructed to the ECU.
What do you mean by closed loop ?
Its in a MEV rocket, The manifold has never come off, How do I test the Lambda sensor is working ?
The temp reading got to 62, so I presume it got warm enough.
