Z20let Corsa
| posted on 24/2/09 at 04:42 PM |
IRS setup drawings. Independant suspension.
does anyone have any dwawings for the rear of the chassis for independant rear suspension setup?? main chassis is nearly done so now i need the
drawings for the rear. im using sierra hubs. Theres a picture of a locost in ron champions book with irs but you cant see much of it. Thanks. John.
Z20let Corsa
| posted on 24/2/09 at 04:46 PM |
think ive found the correct details now but any info anyone has would be appreciated!!!
locost +4 v8 in progress.
t16turbotone
here they are chaps
http://kit-car.org/Files/suspension/RortyLocostIRSAssembly.pdf
ashg
| posted on 24/2/09 at 04:58 PM |
there are some good drawings in the new haynes manual. you would have to change a couple of dimensions due to your chassis being a slightly different
size but that shouldnt be an issue.
Cobra289
| posted on 25/2/09 at 09:00 AM |
Please be careful with what you want to make.
Because it is a "locost" doesn't need to be a LOW Design.
So there is no way that you can pick this chassis with some front suspension and than pick this or that rear suspension.
It takes a lot of time to have a good definition of the suspensions so I would advise to walk a way that has the full definition of the car. Stick to
that plan and once it drives adjust to your needs.
Chris Gibbs [Haynes publications] book will give you a neat result.
Always better than make combination's of suspensions.
It is not clear what you have, Ron Champion design or a "+4" as you sign.
Sorry if it sound negative but it is NOT.
Regards,
Cobra289
