Author: Subject: Sierra Master Cylinder..??
grassracer
posted on 25/2/09 at 01:02 PM Reply With Quote
Can anyone tell me the size of the large hole needed in a bulkhead to take a Sierra Master Cylinder, also what are the spacings between the bolt holes to mount the cylinder. Thanks in advance
posted on 25/2/09 at 01:35 PM Reply With Quote
there are at least 2 different types; pretty sure they are not intechangeable.
I have one type that I can provide info. if you want.
Mark Allanson
posted on 25/2/09 at 06:21 PM Reply With Quote
There are 4 types, 3 cast and 1 drawn tubular one. The tubular one has a bolt patern the same as the pedal box so you can simply remove the servo and bolt back up again. Not so with the cast varieties.
posted on 25/2/09 at 06:32 PM Reply With Quote
There are at least 6 different types of Sierra brake master cylinders. 3 Girling and 3 Bendix.
Phil
