Daddylonglegs
| posted on 6/3/09 at 03:22 PM |
Steering Arm Extensions
I know there are pre-made extension pieces available, but I have the offer from a local engineering firm to knock me up some for a
'contribution'
I just wondered how best to work out how long they need to be and what depth of thread inside the tube etc.
It's a standard escort rack with cortina hubs on a +442.
Cheers.
JB
907
| posted on 6/3/09 at 04:48 PM |
Hi. Is this any help?
In theory if you are +4" then the body of the extension should be 2".
I found that a little more thread was available on the track rod so I made mine a little longer.
HTH
Paul G
p.s. The stud is 40mm long held in with a roll pin.
Edit to add. I have a book chassis that has 4" added to the center (to make it +4) with book wishbones.
[Edited on 6/3/09 by 907]
Daddylonglegs
| posted on 6/3/09 at 08:40 PM |
Thanks for that Paul.
I guess the best thing for me to do is get the guy to tap a rod as you've got there and pin a threaded bar. Can you remember what the thread is?
I seem to remember it is M14 x 2 but not sure?
John
907
| posted on 6/3/09 at 08:56 PM |
I think you are right
Paul G
