Jasongray5
| posted on 9/3/09 at 10:58 AM |
What kind of sierra diff is this??
Its got no tag on it, The top measures 7.5" the bottom 7" It has push in shafts, it came from a 2.0 DOHC and the ratio is 3.92??
Image deleted by owner
[Edited on 9/3/09 by Jasongray5]
MakeEverything
| posted on 9/3/09 at 12:06 PM |
Its one with an aluminium casing from a 2.0 DOHC with a possible ratio of 3.92....
Kindest Regards,
Richard.
James
| posted on 9/3/09 at 12:26 PM |
Wow! An actual larger than life photo!
Err, it has push-in shafts?
What are you asking? You seem to know everything there is to know about it?
I don't think anyone can tell you the diff' ratio if that's what you want. Chances are it's 3.92 though.
I would make a mark on one of the CV joints, turn the input flange and then see how much the shafts turn... count 'em and see.
Hope that helps,
James
- Muhammad Ali
Paul TigerB6
| posted on 9/3/09 at 12:52 PM |
Only thing else to add is that it is an open diff as opposed to a Limited Slip Diff
Jasongray5
| posted on 9/3/09 at 01:42 PM |
Does anyone know how easy its going to be to get in into the roadster chassis? And I thought all 7.5" diffs had bolt on shafts?? Hence why I
thought it was odd
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
Richard Quinn
| posted on 9/3/09 at 02:05 PM |
7" or 7.5" is the size of the crown wheel. If the top mount has a bit of a cutaway in it (so you can see the bolt when it is in situ) then
it is probably a 7".
| posted on 9/3/09 at 03:09 PM |
It's a 7 inch diff, none of the 7.5" units had push in driveshafts AFAIK.
jacko
| posted on 9/3/09 at 04:53 PM |
My 2l dohc donor had bolt on shafts 3.62
Jasongray5
| posted on 10/3/09 at 12:22 AM |
This is what confuses me!!! It has the solid upper mount as per a 7.5" diff, and measures about 7.5", BUT!! it has push in shafts???
How hard can it be?
jacko
| posted on 10/3/09 at 05:13 PM |
I have just found out that some 2L Dohc cars have 3.91 diffs that are 7.5 and push in shafts
if this helps you
Liam
| posted on 11/3/09 at 05:22 PM |
And, conveniently, the measurement accross the top mount. This is definately a 7.5" diff.
Liam
