Author: Subject: Setting up floor mounted pedals?
Northy
posted on 13/2/04 at 06:04 PM Reply With Quote
When floor mounted pedals are set up properly should the pedals sit upright, or sloping towards the driver?
I've got a Luego Gold pedal box if it makes any difference.
Graham
GO
posted on 13/2/04 at 06:06 PM Reply With Quote
Provding you've got enough movement, I'd just set them up so they're comfortable.
Donners90
posted on 13/2/04 at 06:19 PM Reply With Quote
Gold pedal box
Sorry for hijacking your post, but out of curiosity, what comes with the GOLD pedal box from Luego? I was thinking of getting the GOLD box over the standard one - Is it worth it?
James
Northy
posted on 13/2/04 at 06:34 PM Reply With Quote
The problem is I need to make up a tube for the clutch cable to run through, and the length of this alters where the pedal sits. Because I've not welded the tube to the chassis, I can't try the clutch
A vicious circle
I don't know what you get in the "standard" pedal box, but the Gold one is powdercoated, which is a complete waste of time because you have to drill holes in it!!!!!
Graham
posted on 13/2/04 at 07:15 PM Reply With Quote
i made mine all roughly upright. And then i found they were too far back to be comfortable and so i welded an extension onto each. Now they lean toward me a bit, feels better. As for the tube that the clutch goes thru, just tack it and see. Thats what i did, with some 3/4 inch tube.
wicket
posted on 14/2/04 at 06:25 PM Reply With Quote
Graham
The operating face of the brake pedal is nominally vertical at rest (the clutch pedal appears to be also, not finally connected but a quick check looks to bring it to about the same position as the brake pedal). At rest the brake pedal face is 50mm approx. from the pedal box flange, pic in my archive, Pedal_Box_6a.
Eric
Northy
posted on 14/2/04 at 06:44 PM Reply With Quote
Cheers Wicket
Graham
