New Topic New Reply
Author: Subject: fireblade clocks
willgal
posted on 10/3/09 at 02:11 PM Reply With Quote
fireblade clocks
Hi Everyone
I boughht mk indy blade a year ago but have never had the speed clock work, but the rev counter does, the fellow before me had a digi push bike speedo but it doesn't work very well. i am fitting a gear indicater on it so i need it to work any ideas please
Mark G
posted on 10/3/09 at 05:58 PM Reply With Quote
Is there a speed pickup sensor on the prop or wheels anywhere?
posted on 10/3/09 at 06:00 PM Reply With Quote
What year is your blade engine?
Phil
willgal
posted on 11/3/09 at 08:52 AM Reply With Quote
There is no pick up on the prop shaft sproket and the engine is a 919 fireblade not sure on the year.
I have a reed sensor , will that work with the clock you think??
mkblade
posted on 14/3/09 at 12:06 AM Reply With Quote
the 919cc should have the speedo pick up
should be located next to the starter motor
willgal
posted on 19/3/09 at 02:34 PM Reply With Quote
hello there
yes i found it, it does have a pickup at the side of the starter motor. doesn't seem to be any place to wire it too, there is 3 bolts on it, 2 to attach it too the engine and 1 cover a screw on the top, can't find were i connect the wires to tho, help please
New Topic New Reply
