Author: Subject: Cheap Differential Options
liam.mccaffrey
posted on 10/3/09 at 10:35 PM Reply With Quote
The diffs I have are as follows;
2 x MX5, 1.6lt open diff
1 x XR4x4 LSD diff
I'm going to end up with 350 HP plus so I need something a little more robust. I have heard the MX5 diff can go bang before you hit 200HP and even less with higher torqe. I am not sure the XR4 diff can handle much more than that.
I believe you can swap in RX7 differentials to the MX5 diff but apparantly its only the 1.8lt diff casing.
I could sell the MX5's and swap in a quaife to the XR4x4 diff, how much can they take?
Or should I look elsewhere, Jag, BMW, Volvo, Merc etc. Anyone have any thoughts and prices. Anyone have anything laying around?
LSD option is a must really, and its not for a 7 so size isn't an issue.
Build Blog
Build Photo Album
MkII
posted on 10/3/09 at 10:40 PM Reply With Quote
i had a xr4x4 diff in a300hp sierra cosworth it did about half a seasons hillclimbing befor all its insides ended up on the floor!. m.
lsdweb
posted on 10/3/09 at 10:42 PM Reply With Quote
Liam
What about Subaru? Not sure what kind of BHP they'll take? Prices are good though! Rescued attachment DSCF7874.JPG
liam.mccaffrey
posted on 10/3/09 at 10:54 PM Reply With Quote
good call will look into it,
That workshop where your car is has a Pratts oil sign on the wall, my boss in the states his father worked for pratts oils and he has a lot of old signs and memorabilia.
They are very proud of their oil company history. We went to this museum in a small town called Drumright and they even had documents relating to the construction of our Gulf oil terminal in Milford Haven.
Build Blog
Build Photo Album
lsdweb
posted on 10/3/09 at 10:57 PM Reply With Quote
The diff in the picture cost me £60 including driveshafts! I'm not sure if it's an LSD although the guy did think it was. I bought a brand new one (LSD) for £160!
meany
posted on 10/3/09 at 11:09 PM Reply With Quote
i was gonna subaru aswell.
r160 WRX/uk turbo or the bigger r180 STI
both are LSD.
[Edited on 10/3/09 by meany]
Paul TigerB6
posted on 10/3/09 at 11:20 PM Reply With Quote
Bargain!! What ratios are the Scooby diffs please Wyn??
clairetoo
posted on 10/3/09 at 11:23 PM Reply With Quote
There are plenty of 200+ BHP Mx5's out there - loads of V8 ones on Utube.......?
Its cuz I is blond , innit
Claire xx
Will weld for food......
liam.mccaffrey
posted on 10/3/09 at 11:29 PM Reply With Quote
I had a ride in a supercharged miata when I was in Oklahoma, it had about 220 but had a torsen diff. I just want to future proof it a little bit as I'm shooting for more than 200
[Edited on 10/3/09 by liam.mccaffrey]
Build Blog
Build Photo Album
meany
posted on 10/3/09 at 11:30 PM Reply With Quote
depends what it came out of.
i have a link somewhere.
here you go
http://www.northursalia.com/techdocs/trannychart/trannychart.pdf
alistairolsen
posted on 10/3/09 at 11:39 PM Reply With Quote
Am I missing something or is there no rear diff info there?
liam.mccaffrey
posted on 10/3/09 at 11:42 PM Reply With Quote
I can see a final drive ratio
Build Blog
Build Photo Album
alistairolsen
posted on 10/3/09 at 11:49 PM Reply With Quote
doh, not thinking straight at this time of night
Paul TigerB6
posted on 10/3/09 at 11:56 PM Reply With Quote
LOL - quickly worked out it was the Final Drive ratio column fortunately. Seems like they are great for the sprinters with 3.9:1 or shorter, but no good for the BEC boys!! Ah well.
Cheers for the link anyway
irvined
posted on 11/3/09 at 11:26 AM Reply With Quote
There is a couple of options with the mx5 diff,
As stated there are some high powered mx5s around, but the diffs do get a bit fragille after 200bhp. They tend to break around the bearing clamps, or the pinion bearing.
The diff from the RX7 is almost identical, and you can swap most of the bits around, i think you use the rx7 diff in the mx5 casing basically.
You can also buy off the shelf replacements such as a torsen, but whilst that will stop the cross pin snapping, it wont fix the other failure points.
http://irvined.blogspot.com
