flak monkey
posted on 15/2/04 at 09:23 PM |
Steering Column Offset?
Does anyone know what the steering column offset is if you are not using a crushable column?
Another quick Q, did the later Capris have a crushable column?
Sera
http://www.motosera.com
theconrodkid
posted on 15/2/04 at 09:26 PM |
for sva you need a colapsible column and lower u/j at least 10 deg angle,if the column has a triangular tube that is the colapers
who cares who wins
pass the pork pies
flak monkey
posted on 15/2/04 at 09:32 PM |
So 'The Book' is wrong in saying you can use the Escort column then, 'cos none of them were crushable. I know it also suggests
Sierra columns.
I was hoping to get away with using all the bits off a Capri hence the second second question above.
Sera
stephen_gusterson
posted on 15/2/04 at 11:38 PM |
the book is wrong in MANY respects!
Book one has a car with single cct brakes - not allowed. And has a winscreen with no wipers or demist facility.
get a copy of the sva manual and treart anything in 'the book' with a lot of caution!!!!!!!!!!!!
atb
steve
Mark Allanson
posted on 15/2/04 at 11:42 PM |
Basically what Steve is saying is that the book is great for the initial inspiration, and for steadying unstable table legs down the local boozer
Mark Allanson
posted on 15/2/04 at 11:43 PM |
flak monkey
posted on 15/2/04 at 11:51 PM |
Thanks for the warnings guys i know the books got errors in it, quite a few on the chassis alone. Having done the CAD model I have picked up on
them
Ok so I am probably about to look stupid; Steve, what are CCT brakes?
Sera
Mark Allanson
posted on 16/2/04 at 09:17 PM |
Cingle CircuiT?
Browser
posted on 26/2/04 at 04:19 AM |
In fairness to Ron Champion the book was first published pre-SVA. Having said that it hasn't been changed a lot since.........
