| posted on 17/3/09 at 04:17 PM |
quick question on live axles
hi peeps. Just wondering if the oil is free to slosh from end to end or if its held by the diff somehow?
Cheers!
Dangle_kt
| posted on 17/3/09 at 04:18 PM |
oil its held inside the axle by bearings as far as I could tell.
But they are at the hub ends, so I think it can slosh freely. Thats what I found anyway, but best wait for someone clever.
locoR1
| posted on 17/3/09 at 04:21 PM |
If i remember right the English axle has some baffle plates in it!
Check out my CB500T Cafe Racer build diary
NigeEss
| posted on 17/3/09 at 04:24 PM |
Oils eals on the outside of the wheel bearings, oil can slosh back and forth to its
hearts content and keep those shiny bearings healthy.
alistairolsen
| posted on 17/3/09 at 04:27 PM |
so if you drove round and round in a circle then the inner bearing and diff would eventually fail?
clairetoo
| posted on 17/3/09 at 04:33 PM |
Not quite - the wheel bearings themselves are sealed , and there are baffle plates either side of the diff .
Its cuz I is blond , innit
Claire xx
Will weld for food......
yellow melos
| posted on 17/3/09 at 05:29 PM |
i am sure you would have to stop because you felt sick before the diff wears out
minitici
| posted on 17/3/09 at 07:07 PM |
Most diff oils are fairly viscous and don't slosh about much!
| posted on 17/3/09 at 07:10 PM |
Some Escort Hot Rod racers used to use an external Jabasco electric bilge pump to deposit the oil back over the pinion.
Daddylonglegs
| posted on 17/3/09 at 09:23 PM |
Yep, UR right. Threre is a baffle in each tube, just outboard from the banjo casing.
JB
