Author: Subject: Pedal cable clamp... Things.
Staple balls
posted on 22/3/09 at 11:19 PM Reply With Quote
Getting ready to fit pedals in the nearish future, brakes are already sorted with clevis etc.
But for the cable-y pedals, I'm thinking along the lines of:
Cable Idea
Cable Idea
But shorter on the end the bolt goes in, for the sake of compactness.
Reckon it'd work?
Flamez
posted on 23/3/09 at 06:19 AM Reply With Quote
it would work but ready made cables come with a loop for the pedal end,just slip the bolt through.
my build mac1motorsports
Staple balls
posted on 23/3/09 at 06:25 AM Reply With Quote
Difference being that I can't get ready made cables for free out of the shed.
Phil.J
posted on 23/3/09 at 09:44 AM Reply With Quote
That looks like a cable guillotine to me!
Staple balls
posted on 23/3/09 at 09:53 AM Reply With Quote
hmm, good point. I'll have a play with a spare cable and see if I've invented a new tool
posted on 23/3/09 at 10:14 AM Reply With Quote
The easiest thing to use is the metal bit inside a chocolate block type DIY wire connector. Take out the screws, slide the metal bit out of the plastic bit and bingo. One either side of the pedal....
Lightweight and cheap....
Staple balls
posted on 23/3/09 at 04:00 PM Reply With Quote
Just had a good play using cycle gear wire.
even just done up finger tight, it'll support my weight (19st-ish) pulling on it.
Also, it doesn't seem to damage the cable significantly when tightened all the way down, no broken strands, even after bending back and forth for a while.
nstrug
posted on 23/3/09 at 09:15 PM Reply With Quote
Take a bolt, drill across it (2mm hole should be enough), then use two penny washers and two halfnuts to sandwich the cable threaded though the hole.
Works brilliantly and doesn't cut the cable.
Nick
