chrisg
posted on 28/3/09 at 12:07 PM |
Relay identification.
I'm looking for a relay for my radiator fan, I also have a big bag of relays.
The problem is that I can hardly wire a plug - how do I identify a suitable relay?
ta muchly
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
theconrodkid
posted on 28/3/09 at 12:24 PM |
http://www.reuk.co.uk/Automotive-Relays.htm
who cares who wins
pass the pork pies
Paul TigerB6
posted on 28/3/09 at 12:43 PM |
Are you just looking for one to switch the fan through a dash switch? If so then a simple 4-blade one should do it.
linky to diagrams
chrisg
posted on 28/3/09 at 12:54 PM |
Thanks chaps, I need one that works from the thermo switch and a dash switch.
Chris
les g
posted on 28/3/09 at 01:05 PM |
chris fone me i have sent u2u will talk u through it
les g
snapper
posted on 28/3/09 at 01:10 PM |
Can't quite work out why you would both?
If you set the thermostat switch correctly it should come on and stay on until the temp drops, the switch would only turn it on earlier (if you need
to do this just set the thermostat to come on earlier) or turn it off befor the temp has dropped enough.
I eat to survive
I drink to forget
stevebubs
posted on 29/3/09 at 04:00 PM |
If you're working on a switched ground for the relay activation switch, then just fork the connections - send one leg off to the temp switch and
the other to your dash over-ride. Connect the other side of both switches to ground.
chrisg
posted on 29/3/09 at 08:15 PM |
Thanks or the replies guys - I took the easy way out and got my Brother-in-law to sort it, all wired up now
Chris
