Author: Subject: Calculating split rim section sizes
v8kid
posted on 30/3/09 at 10:43 AM Reply With Quote
How do I work out what sizes of inner and outer sections to use in a split rim wheel?
The center section does not look flat as if there is some offset already inbuilt so it would not be as simple as dividing the width by 2 and deducting the offset for the outer and adding the offset for the inner. Would it?
Paul TigerB6
posted on 30/3/09 at 01:50 PM Reply With Quote
Now i wonder why you are asking this today!!
Does this answer your question??
linky
v8kid
posted on 30/3/09 at 02:02 PM Reply With Quote
Ta Paul,
I had seen that before but never read it properly! So there are different centers depending on the ammount the brake caliper protudes - any idea the most common one - no point in buying a center I can't resell!!!!
