eddbaz
| posted on 30/3/09 at 12:07 PM |
prop grease
What type of grease do I need to lubricate my prop u/j's ?
wilkingj
| posted on 30/3/09 at 12:23 PM |
I use standard Lithium wheel bearing grease.
Best Regards
Geoff
http://www.v8viento.co.uk
| posted on 30/3/09 at 12:37 PM |
Castrol LM because it's what I have. Use it for wheel bearings and everything that spins, lithium high melting point grease.
| posted on 30/3/09 at 01:07 PM |
thirded - Castol LM grease
dhutch
| posted on 30/3/09 at 02:18 PM |
I have a grease gun full of Castrol Moly Grease (lithium base) , is that suitable?
- Use it for trailer wheel bearings mainly.
Daniel
| posted on 30/3/09 at 02:32 PM |
Moly is fine also -- main thing is to keep enough grease in it the water out
| posted on 30/3/09 at 04:41 PM |
Do you have to just do ones with grease nipples or do they all need doing?!?!?!
| posted on 30/3/09 at 06:49 PM |
You can only grease ones with grease nipples!
