maartenromijn
posted on 30/3/09 at 06:52 PM |
Zetec throttle cable stroke
I am designing my pedalbox at the moment. I do not yet have the Zetec. Can anyone tell me the stroke of the trottle cable? I will make something like
this:
Pedalbox seven on the street
BLOG: http://thunderroad-super7.blogspot.com/
big_wasa
posted on 30/3/09 at 08:08 PM |
That will depend on things like what carbs or what Tb's and what linkage and so many other things.
will121
posted on 31/3/09 at 07:20 AM |
as above what carb/throttle bodies are you using? as a gess would think about 40-50mm can measure tonight as have a selection of carbs and throttle
bodies, can you at this stage form a number of cable connection positions in the pedal to alow for changing the action ratio's
maartenromijn
posted on 31/3/09 at 08:26 AM |
I willl try to use the standard inlet manifold. If I make it adjustable I still need to know the approx stroke to maintain the ratio. Wat is the
normally used ratio?
will121
posted on 31/3/09 at 04:53 PM |
fiesta zetec throttle pedal has cable connection to pivot point 70mm, various strokes of throttle cables, standard zetec single RS1800 silver top
throttle body 30mm. GSXR750 throttle bodies 22mm & ZX9 carbs 22mm hope it helps
