bassett
| posted on 30/3/09 at 08:45 PM |
Wheel nut torque?
Hi, how tight do you do your nuts? wondering as i had mine set to the same as the tin top and thought that would be ok but during my sva i removed two
nuts as requested and one had the thread slightly buggered - dreading checking the rest now
Adam
flak monkey
| posted on 30/3/09 at 08:49 PM |
Personally I dont torque them....
I do them up tight with a wheel wrench and thats it. They are very unlikely to come undone....
The only bolts I torque are things like suspension bolts and head bolts, I do pretty much everything else by 'feel'.
Sera
http://www.motosera.com
mangogrooveworkshop
| posted on 30/3/09 at 08:53 PM |
110 nm torques
bassett
Hi, Yeah i know what you mean but with my choice of tools are either a short 1/2 inch ratchet and im always left feeling they could be tighter and the
next step up is my 24" breaker bar which would certainly ruin them without feeling tight. Knowing a rough torque NM or LBFT setting would just
be piece of mind.
Adam
| posted on 30/3/09 at 08:57 PM |
110Nm for me too Same as my clutch nut!!!
bassett
| posted on 30/3/09 at 09:03 PM |
Wicked il go with 110nm, i was running a bit higher than that so hope they aint all buggered - fingers crossed!
tomgregory2000
just tight and copper grease so i can take them off agen
nstrug
| posted on 30/3/09 at 09:08 PM |
I have alloy M12 wheelnuts and use 90Nm. Copper slip them and you should be fine.
Nick
tegwin
| posted on 30/3/09 at 10:05 PM |
after watching someone snap a wheel stud in the hub with a wheel rench I now always use a torque rench.... set to 90! Cant go wrong!
www.verticalhorizonsmedia.tv
alistairolsen
| posted on 30/3/09 at 10:13 PM |
I use 110Nm as recommended for my vauxhalls, and will prolly go with that for the locost in the absence of a mazda manual.
Chippy
| posted on 30/3/09 at 10:32 PM |
70 lb's foot for mine, works fine, never stripped any, or broken any,  Cheers Ray
| posted on 30/3/09 at 10:58 PM |
The correct torque setting for both Cortina and Sierra wheel nuts is 90 Newton Metres.
