posted on 31/3/09 at 02:57 PM |
Master Cylinder Swap?
I hate my twin bias remote resevoir set up as there is always a puddle of fluid on the chassis.
I've tried a couple different methods but the union at the cylinder and pipes down from the reservoir leak...
Anyone used the integral type? Is there a problem with the distance between the two on a bias setup?? Should make for a neater looking
setup....
bimbleuk
| posted on 31/3/09 at 04:20 PM |
I'm using two Wilwood integral master cylinders. The distance apart will be dictated by the balance bar setup. I've literally just
finished removing the copper piping from the front circuit and replaced it all with braided hose. Filled, bled and run down the road, no leaks from
any of the new lines and joints.
