Author: Subject: Shock homeBuild or Buy ?
lamhotung
posted on 30/7/02 at 04:09 AM Reply With Quote
$$$ = shock
http://www.gibbs111.fsnet.co.uk/buildtip.htm#home build shock.
how is the quality of home build shock??
anyone know?build or buy?
regard TT
James
posted on 30/7/02 at 03:49 PM Reply With Quote
Erm....
What the shuck are you on about?
James
bob
posted on 30/7/02 at 05:05 PM Reply With Quote
James
Its build yer own shock absorbers mate.
Its possible,but the people i've met who built them from motor bike shocks allways end up buying proper ones in the end .
Bike shocks dont last that many miles on bikes so there's a limited life.
johnston
posted on 30/7/02 at 07:56 PM Reply With Quote
i was lookin at the mini shocks in work and started lookin at other ones noticed jag ones monroe number 43013 (i think or somethin similar) already has a lower platform on it. means only a top one has to be made. and is also about the same length of the mini one.
chrisg
posted on 30/7/02 at 10:05 PM Reply With Quote
I've got modified Mini ones on the front of my car.
How good are they? - Depends how good you are at making them!
Bear in mind that the "standard" ones aren't adjustable for ride height - you have to insert "c" washers under the spring to raise it.
Mine cost £12 each though.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
stephen_gusterson
posted on 30/7/02 at 10:08 PM Reply With Quote
I was toying with the idea of what i might do for a future project, should i ever get this one finished!
I was thinking of a trike, kinda like, but not too like, a bond bug.
That made me do a bit of research on the net on reliants! (bug had the chassis).
Two interesting things : 1, - probably not wide enougth or too low power - but the reliant has a live rear axle that weighs only 75 lbs.....
2. It seems to have coil overs........
any interest?
atb
steve
James
posted on 31/7/02 at 04:06 PM Reply With Quote
James
Ok, guess I should have checked the link! Sorry!
James
paulf
posted on 31/7/02 at 09:23 PM Reply With Quote
Ive got a pair of mini ones on the back of my car, i made threaded sleeves and alloy springseats and top mounts.
I am also building a pair of Gas monotube dampers from scratch to fit on the front. There is a design very similiar to the Nitrons on the file area of the other list, however it needs a fairly well equiped workshop and is a long term project. i have a pair of Avos on the front at present.
Paul.
Chris
lamhotung
posted on 3/8/02 at 12:47 AM Reply With Quote
i will buy them
making them seem like too hard to get them right...
where to get a good shock?
my car call hicost 7 j/k
paulbeyer
posted on 3/8/02 at 09:52 PM Reply With Quote
Try http://www.nitron.co.uk they do a complete set for a Locost for less than 200 notes (+vat for UK residents).
