Author: Subject: remote oil pressure pipe
mkblade
posted on 11/4/09 at 05:14 PM Reply With Quote
hi all
im trying to install a remote oil pressure/sensors
taken the old pressure switch out
screwed the union in its place
now im havving trouble tightening the aeroquipe hose union (cant get a spanner in there to tighten it enough.
its a rrx blade engine 919cc the oil pessure switch sits in a recess at the back of engine and its a royal pain .
has anyone eles had trouble ?
cheers
simon
greggors84
posted on 11/4/09 at 05:58 PM Reply With Quote
You can get imperial crowfoot spanners that are great for hose fittings in tight spaces. I know snap on do most sizes, but a search on ebay should find you the size you need. What fitting is it?
If your worried about marking the ali fittings wrap them in a bit of tape.
[Edited on 11/4/2009 by greggors84]
Chris
The Magnificent 7!
Mark G
posted on 11/4/09 at 07:35 PM Reply With Quote
If possible can you post up a couple of photo's of what your doing and also what parts you've used as I need to do this to my 893 blade when the SVA's out of the way.
bigfoot4616
posted on 12/4/09 at 06:29 PM Reply With Quote
you sure your trying to fit it to the right place?
mine is at the front of the engine and has plenty of room around it
