Author: Subject: Help identify column bush
Andy W
posted on 13/4/09 at 07:27 PM Reply With Quote
Hi
My steering column u/j has a bush attached which is worn, can anyone identify which car this from. I would guess a ford? also is just a case of knocking the pin out to fit a new one?
Column bush
Column bush
Thanks Andy
posted on 13/4/09 at 08:42 PM Reply With Quote
Not from a Ford that I recognise. Similar to a Sierra coupling but different. Might?? be from someone like CBS or Rallydesign?
posted on 13/4/09 at 11:03 PM Reply With Quote
I think It's the coupling from the V6 Sierras. The shaft is originally bonded into the rubber, it's not possible to replace the rubber part separately, and AFAIK these couplings are not available new any longer.
Best option would be to get a sleeve turned up of the correct diameter to weld into the body and onto the shaft, or replace it with the more useful Sapphire type coupling.
