Author: Subject: DIY Tracking
iiyama
posted on 15/4/09 at 08:54 AM Reply With Quote
DIY Tracking
Done a bit of a search and got myself totally confused!
Want to get the tracking set reasonably accuratly, (will get it into a laser tracking place at a later date).
Ive set the steering wheel straight, what next??
A/ B/ C/ instructions please for a tracking noob!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
posted on 15/4/09 at 09:21 AM Reply With Quote
A. get a long straight plank/straight edge
B. set it against the rear tyre level with the wheel centre and parallel to the floor
C. adjust track rods so that the plank touches the front tyre (fore and aft) level with the wheel centre.
(Assuming front and rear track are the same)
This should get you straight enough to dirve to the tyre place whithout wrecking your tyres.
iiyama
posted on 15/4/09 at 09:53 AM Reply With Quote
Already done that Paul, so I got something right then!!
Front track is slightly narrower then the rear on the Dax.
posted on 15/4/09 at 10:08 AM Reply With Quote
If you get the steering centred up and the rear wheels pointing reasonable "square" to the car centreline r then wih a Gunsons Trakrite measure set the tracking accross the axles as accuarately as a mega buck laser tracking system.
When iniitially setting the rear end up it helps a lot to establish the chassis centre line that you can take mesurements from. These days as long as you have a flat garage floor and a wall or board to use as a target using two or three cheap laser spirit levels it is quite easy to get the rear wheels reasonably "square" to the chassis centreline. From that point you use the trackrite to measure the toe-in/out and as long as you adjust equally on both sides all will be well.
[Edited on 15/4/09 by britishtrident]
iiyama
posted on 15/4/09 at 10:15 AM Reply With Quote
The rear tracking is fixed on the De Deon set up I have with the Dax, hopefully the factory use a jig to build it!!!
iiyama
posted on 15/4/09 at 10:53 AM Reply With Quote
Sorta depends on how much the equipment would cost? I really like doing stuff myself but the diminishing returns equation has to set in some time!!!!
posted on 15/4/09 at 11:09 AM Reply With Quote
Depends on how you mean tracking (also depends on how adjustable you car is).
For camber I put the car on a flat surface and used a cheap inclinometer off Ebay. They have a magnetic base which stuck onto the brake disc nicely and gave me a camber reading easily. Screwed in / out the top swivel to adjust camber. Job done.
For toe in / toe out I used some toe-in calipers my brother welded up. They're easy to make out of box section if you can weld and allow you to compare the distance between the front of the alloy and the back of the wheel. The difference between the two gives you the toe-in / toe-out. Or you can do what I did and adjust them so that the distance between the front and the back of the wheels is the same (ie no toe-in) then screw in the TRE a little to give a smidge of toe-in (couldn't be bothered to do the maths)... If that doesn't make sense give me a shout and I'll do a diagram (easier to draw than explain but fundamentally a few bits of box section and two bolts!!!)....
iiyama
posted on 15/4/09 at 11:25 AM Reply With Quote
Following ya all the way Ben, unfortunatly I dont have any welding skills, or the equipment to give it a go. (Hence buying a kit and not building from scratch!!)
craig1410
posted on 15/4/09 at 11:57 AM Reply With Quote
To measure toe angle, just roll the car back 1 meter on level ground then roll it forward again to settle the suspension. Set the steering absolutely straight ahead and locked off so it can't move.
Now, stick some masking tape to the tyre contact surface in the middle of the tread at the exact 3 o'clock position level with the hub centre (assumes nearside wheel) and make a vertical pen mark on it. Now transfer this mark to the floor using a set square or plumb bob onto another firmly stuck piece of masking tape. Do the same on the offside wheel only it is the 9 o-clock position this time.
Now roll the car forward (don't let the steering move at all) until the tyre has rotated 180 degrees. The nearside mark will now be at 9 o'clock position and the offside at 3 o'clock. Transfer the marks to the ground as before on both sides.
Now roll the car out of the way and measure distance between front and rear marks. If front > rear then it is toe-out otherwise it is toe-in (or zero toe if equal).
You can work out angle as follows:
Angle = Inverse Sin (d / D) where d is the toe distance and D is the diameter of the tyre (not wheel). This will give total angle so halve it to determine per-wheel angles. If you want to stick with millimeters instead of angles then you need to multiply d by (rim diameter / tyre diameter) since most measurements talk about wheel toe not tyre toe.
This method is recommended in Des Hamill's excellent book on suspension design and should be pretty accurate as long as you lock off the steering and measure accurately.
I hope this helps,
Craig.
iiyama
posted on 15/4/09 at 12:15 PM Reply With Quote
I will have to digest and cogitate over that craig!! Printers at the ready and a brew is on the way!
craig1410
posted on 15/4/09 at 12:32 PM Reply With Quote
It's easier done than said...
iiyama
posted on 15/4/09 at 01:17 PM Reply With Quote
The kind of work that I like!!
