Author: Subject: Sera diff sizes
ceebmoj
posted on 23/2/04 at 04:38 PM Reply With Quote
Sera diff sizes
Sera diff sizes
Does anybody know the diameter of the cv joint on the sera and how many bolts there are that hold it on to the diff.
PS sorry about my spelling and grammar
James
posted on 23/2/04 at 05:13 PM Reply With Quote
6 bolts.
Diameter *about* 120mm but check with someone if you want it more accurate than that.
HTH,
James
keith2lp
posted on 23/2/04 at 09:23 PM Reply With Quote
The haynes manual quotes 2 sizes of CV joint. 100mm dia & 108mm dia and yes there are 6 M8 bolts.
stephen_gusterson
posted on 23/2/04 at 10:08 PM Reply With Quote
only one type bolts on. the other slides in splines.
Beware - if they are T40 headed bolts, they are bastards to get out. The T bit will often break.
I ended up grinding the top off some of mine - once you do that the joint can slide off the bolt shaft, and it comes out by hand!
atb
steve
