tilly819
| posted on 19/4/09 at 03:55 PM |
sierra push in drive shaft CV joints
Hi all,
just a quick one, how to you get the sierra drive shafts (diff to rear wheels) CV joints apart to replace the rubber gaitors
chears tilly
gingerprince
| posted on 19/4/09 at 04:03 PM |
I've just had mine done (got my brother to do it whilst he was replacing the bearings as I don't have the tools to do/undo hub nut
F.Tight!).
You can't just replace the boot, you have to replace the can as well. As far as I know you have to cut the can off, then replace it and peen it
over the grease seal at the non-boot end. Bit if an "entertaining" job.
Boot kits were about 10 quid from Ford, which included a boot, can and grease sachets.
[Edited on 19/4/09 by gingerprince]
matt_claydon
Simple answer - you don't. Best bet is to use a stretchy or split (glue together) boot. Otherwise you have to cut the casing off the joint and
fit a new one with the boot.
[Edited on 19/4/09 by matt_claydon]
tilly819
| posted on 19/4/09 at 04:20 PM |
hmm thats abit off a bummer, i think going down the stretchy boot or glue together is apealing were abouts would i get such a thing?
Im neer nottingham by the way
chears
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
matt_claydon
| posted on 19/4/09 at 04:47 PM |
http://www.bailcast.com/en-gb/products/list/universal-cv
I used one of their sticky boots and although I had heard bad opinions and had reservations it's been on my Indy for 6000 miles with no
problems. Done on the car it would be a nightmare to do properly, but with the shaft on the bench and everything clean you canmake a very good
join.
Stretchy ones are probably better though but a little more expensive.
Also: http://www.stretchyboot.com/
johhny5
posted on 19/4/09 at 05:21 PM |
I would also reccomend the stretchy boots, use plenty of lubrication
As as previous post you wont need to cut off the shield,
seems all good
tilly819
| posted on 19/4/09 at 06:50 PM |
fantastic 4 new universal stretcy boots on order
thanks for the help
