Author: Subject: Impreza Transaxle
GRRR
posted on 20/4/09 at 11:23 AM Reply With Quote
Impreza Transaxle
Hi all,
Does anyone think the impreza transaxle would be happy putting all the engine's power through the front driveshaft output having had the OP to the rear diff blanked off?
A lightweight kit car should minimise stresses and plenty of companies make LSDs for the Impreza front diff, but I assume in the Impreza it never sees much more than 50% of the torque.
Any help much appreciated!
Richard Quinn
posted on 20/4/09 at 11:31 AM Reply With Quote
I think that this is how the latest SDR Storm is being done.
Liam
posted on 20/4/09 at 11:58 AM Reply With Quote
The front output can see most of the engine's torque if the back axle is slipping and the centre diff locks up, so should be rated accordingly.
If you want to run like this continuously you'll have to weld up the centre diff rather than relying on it locking, because a, it can't lock 100%, and b, you'll cook the viscous coupling.
Can't you use a 2WD transaxle from one of the 'lesser' Impreza models? I assume it'd fit the engine and be a much lighter and more compact solution.
Liam
GRRR
posted on 20/4/09 at 12:40 PM Reply With Quote
thanks for the replies guys. Would liek to keep it a '1-donor' solution but I guess a lower spec model would be more suitable and probably strong enough, as long as there's an LSD available, which I'd like to have the option of.
sebastiaan
posted on 20/4/09 at 03:54 PM Reply With Quote
There are OE parts available to lock the centre diff on current Subaru's. We use them all the time at work (we engineer LPG conversions and need to put these cars on a 2WD chassis dyno). I do not know if the parts are also publicly available. I'd check with the UK importer; they might be willing and able to help you out.
