mad-butcher
posted on 22/4/09 at 11:32 AM |
Look what I've Just Ordered
Monies tight
and times are hard
there going on my credit card
can't wait
being made by offroaddevelopments aka wozsher
£130 all in spacers etc
I'm happy with that
Due back at work tonight for another 6 nights delivering newspapers to shops, but when the postman knocks I feel a sickday coming on.
Transit balljoint has been moved back 16mm so should I believe give 6deg what ever it's called
[Edited on 22/4/09 by mad-butcher]
![](/galpreviews/a931687-wishbones indy.jpg) ![Rescued attachment wishbones indy.jpg](/gallery/a931687-wishbones indy.jpg) Rescued attachment wishbones indy.jpg
Mr Whippy
posted on 22/4/09 at 11:34 AM |
price?
blakep82
posted on 22/4/09 at 11:48 AM |
nothing wrong with that they're essential items
had you spent a fortune on something like a dry sump kit when you have a perfectly in order wet sump, then you'd have to justify it
________________________
posted on 22/4/09 at 12:01 PM |
They look the dingly danglies don't they
Keep us posted on fitting and set-up and how they change the handling Tony.
melly-g
posted on 22/4/09 at 12:07 PM |
Where are you getting them from?
mad-butcher
posted on 22/4/09 at 12:13 PM |
they are coming from offroaddevelopments aka wozsher
stevec
posted on 22/4/09 at 01:45 PM |
Oooooooo! I can feel my next upgrade coming on.
Steve.
posted on 22/4/09 at 02:00 PM |
I'm assuming they'll drop straight in...?
StevieB
posted on 22/4/09 at 03:58 PM |
Nice
Does he doe bottom wishbones too? I need to get my car self centering and I;ve heard the difficulty is due to the bottom wishbones being too far
forward, which can be solved using rosejointed suspension and shimming them rearwards in the mounting brackets. Plus they look cool and I want them
![](/images//smilies/bigsmile.gif)
mad-butcher
posted on 22/4/09 at 05:11 PM |
No.. the self centering issue is the top balljoint (transit) being too far forward, these have the transit joint moved 16mm rearward thus inducing
more caster/castor whatever, they also enable camber to be fine tuned instead of to the nearest rotation of the joint.
tony
posted on 22/4/09 at 06:21 PM |
Might just be the picture but there doesn't appear to be much of an angle on the top tube for the balljoint.
Phil
wozsher
posted on 22/4/09 at 07:47 PM |
Top tube has 8 degree angle
greggors84
posted on 23/4/09 at 05:18 PM |
Very interested in these. Let us know how much of a difference it makes.
Chris
The Magnificent 7!
jabbahutt
posted on 24/4/09 at 07:11 AM |
As the rest tony keep us up to date of how the upgrade goes.
I'd be interested in a set of these but would need them chroming. Anyone any idea of somewhere I can get that done.
Is that something Wozsher can get sorted with the order I wonder? If you read this wozsher could you reply with whether chroming is possible and a
price if it is?
