Badger_McLetcher
| posted on 25/4/09 at 09:08 AM |
Alloy Wheel Widening?
I know you can get steel wheels widened by banding, but can the same be done for alloys? And is it legal?
If disfunction is a function, then I must be some kind of genius.
JAG
| posted on 25/4/09 at 09:38 AM |
Not legal for steel wheels and highly dubious (technically) for alloys.
I certainly wouldn't get in a car I knew was fitted with 'widened' alloy wheels
Justin
| posted on 25/4/09 at 09:41 AM |
An accident waiting for a map reference!
omega 24 v6
| posted on 25/4/09 at 10:27 AM |
DO NOT TRY IT.
I've seen steels done before but alloys IMHO would be a HUGE NO NO
ReMan
| posted on 25/4/09 at 10:36 AM |
I cant see any reason why you would need to, given the huge range out there and if there is a tyre there is whell to fit it to, but not the other way
round!"
Badger_McLetcher
| posted on 25/4/09 at 10:56 AM |
I thought it was legal to widen steely's? There's a website that will do steels.
The reason I ask is I've got a set of alloys I like but they could do with being a bit wider. Plus finding wheels wide enough for my PCD that
won't cost me a kidney is proving difficult!
| posted on 25/4/09 at 11:09 AM |
Think you will find widened steel wheels have been illegal for years
austin man
| posted on 25/4/09 at 12:48 PM |
wheel spacers and longer wheel studs is that not an option ???
owelly
| posted on 25/4/09 at 12:51 PM |
'Banding' steel wheels is not illegal. However, should your banded steel wheels cause an accident, then they are illegal!! And
you'll get battered with the big law stick.
http://www.ppcmag.co.uk
tomprescott
| posted on 25/4/09 at 12:53 PM |
Haha, love it!
Doug68
| posted on 25/4/09 at 01:07 PM |
This mob in Germany do alloys apparently its high quality work ~400 Euro for 2 wheels to be +2"
A discussion with pictures here
Doug. 1TG
Sports Car Builders WA
balidey
| posted on 25/4/09 at 03:37 PM |
if you read Allan Staniforths book called hihg Speed Low Cost then he talks about getting wider wheels. He had already gone down the route of banding
steelies *see note below* but decided to get some new alloys cast. So him and some mates clubbed together and got a few sets cast. If he could do that
in the 60's then surely us lot should be able to do the same.
** as far as I can tell there is no law that makes the practice of banding steel wheels illegal. The wheels are not E or TUV marked, so therefore are
not considered illegal if modified. I think where the problem came from was when it was popular every man in his shed thought he could do it, and
proceeded to, and some of the crap that was put on the road did lead to accidents. So the popular belief was that widening them was stupid and also
illegal. In practice there is nothing wrong with doing it, if done WELL.
Fred W B
| posted on 25/4/09 at 04:11 PM |
I agree. Consider the area of weld compared say to the bits that hold a wishbone on, that everyone is happy to do/trust.
Also, consider the fact that the assembly will be subjected to a 100 percent NDT while in service - If a weld develops a crack, the tyre will go
down.
Fred W B
Ninehigh
| posted on 25/4/09 at 06:54 PM |
I've never heard of widening wheels before but I think I'd rather go with trading your old ones in...
MakeEverything
| posted on 3/1/12 at 08:22 PM |
Yes yes, I know his one is dragged out of retirement, but what's the latest? I too have the same problem as the OP, in that I need but cannot
find any cost effective wider rears hat match the fronts.
Kindest Regards,
Richard.
Andybarbet
| posted on 3/1/12 at 08:37 PM |
Im using 205 gti alloys on my build & remember seeing a company that widened them if you wanted, kind of like a set of split rims but with the
alloy centre cut from the 205 gti wheel.
Heres a picture if the above doesnt make sense
  Wdened peugeot alloys
Mgt be worth some research ?? I cant see why these would be 'Unsafe' ??
MakeEverything
| posted on 3/1/12 at 08:40 PM |
Cheers bud. Im looking for a company now. I've decided it's no kore unsafe than some of the other parts on the car! I was wondering if
alone had found a company.
Kindest Regards,
Richard.
Andybarbet
| posted on 3/1/12 at 08:51 PM |
It seems thesemay have been 'made' by compomotive, check out this link with some good close up pictures.
http://www.306gti6.com/forum/showthread.php?id=137805
I will keep researching though because im sure there was a company that would turn 'your' wheels into a similar type of thing.
After all, it only needs some standard split rims & a lathe large enough to cut the alloy rims off your alloys & bolt onto the split rim
surely ??
Or am i missing something major here ?? I have had a whisky tonight
Mmmmmmmmm.......they look great !
  Mmmmmmm :-)
[Edited on 3/1/12 by Andybarbet]
steve m
| posted on 3/1/12 at 09:05 PM |
I do like those 205gti wheels,
were can i get some?
steve
Andybarbet
| posted on 3/1/12 at 09:13 PM |
Here is a picture of one of my wheels after shotblasting, i have always liked them, kind of like a modern minilight design.
  All clean & Blasted
If you like the standard wheel in my picture, just search ebay for peugeot 1.9 GTi alloy wheels, the 1.6 Gti had a different style of wheel but i
prefer the 1.9 version.
phelpsa
| posted on 3/1/12 at 09:15 PM |
http://www.force-racing.co.uk/wheels-15/
HowardB
| posted on 3/1/12 at 09:39 PM |
love their titanium swing arms!! so mamy ££££'s
Howard
MakeEverything
| posted on 5/1/12 at 07:27 PM |
Aah, inner tube required....
http://www.force-racing.co.uk/wheels-10/
Kindest Regards,
Richard.
gazza285
| posted on 5/1/12 at 10:03 PM |
That's only on the 10" two piece wheels.
What's so wrong with tubes anyway?
