Author: Subject: Rubbery squeak after driving
cloudy
posted on 26/4/09 at 10:24 PM Reply With Quote
My rear left wheel bearing (disc sierra) has a rubbery squeak when you push the car around after a drive. It's much like a polybush squeak but quieter - I would guess its the oil seal.
Hub does not get hot, is it worth stripping down? What could cause this?
James
www.warnercars.com
A1
posted on 26/4/09 at 10:28 PM Reply With Quote
id probably say that as long as everything is running okay, its probably not worth it...just keep an eye on it and see if it gets worse.
cloudy
posted on 26/4/09 at 10:31 PM Reply With Quote
I like your thinking
James
www.warnercars.com
posted on 26/4/09 at 10:36 PM Reply With Quote
I would still say it's a polybush squeak!
posted on 26/4/09 at 10:37 PM Reply With Quote
If it gets worse when it's warm - it most certainly will be...
cloudy
posted on 26/4/09 at 10:40 PM Reply With Quote
It's not a bush, it's the wheel bearing - I was just trying to describe the squeak!
www.warnercars.com
posted on 27/4/09 at 08:46 AM Reply With Quote
You sure it's not the pads touching the disk from e.g. a sticky caliper?
cloudy
posted on 27/4/09 at 08:51 AM Reply With Quote
Yup
www.warnercars.com
posted on 27/4/09 at 10:36 AM Reply With Quote
Is it your trainers squeeking on the garage floor with the effort of pushing the car....?
