The Baron
posted on 27/4/09 at 10:42 AM |
Fitting a windscreen
I have managed to bend the windscreen support brackets to the profile of my scuttle and secure them.
What is the best method to fit the windscreen to the support brackets, self tapping screens? M3 screws or similar ? How many of them Etc.
What’s the best method?
B
YQUSTA
posted on 27/4/09 at 11:06 AM |
I drilled and tapped 3x M3's down each pillar on my screen.
RK
posted on 27/4/09 at 12:10 PM |
Ditto.
I had a very hard time putting the bottom on the top part on mine, but getting it to attach to the stanchions was fine.
locoluego
posted on 27/4/09 at 05:18 PM |
same here, didnt realise how much work was involved!! after a few hours getting the bottom rail of the frame mitred to fit the top rail and cutting
both to length, i have decided to buy black pu adhesive to glue the glass to the ally frame instead of using the rubber strip (to much pressing force
reqd). th side frames were bent in at the front to allow the frames to follow the same profile as the scuttle then drilled and tapped the frame to
suit m4 stainless steel button heads remember though to align the frame of the windscreen to the front of the side frames so if your putting doors on
you can screw the hinges to the back of the side frames
locoluego
posted on 27/4/09 at 05:20 PM |
sorry forgot to say 3 per side
RK
posted on 28/4/09 at 12:02 PM |
Having seen what the PU adhesive does, I would avoid that. Stick with the rubber strip. It can really look bad.
locoluego
posted on 28/4/09 at 06:14 PM |
what do you mean?? doese it react with the glass??
RK
posted on 28/4/09 at 10:22 PM |
No it just looks crap. I won't mention any names, but there are reasons for using the rubber stuff, instead of the PU. Won't it slide on
with soapy water on the frame/rubber contact side?
