greggors84
posted on 26/2/04 at 04:53 PM |
Cortina Ball Joint Dims
Does anyone know the dimensions for cortina ball joints, just knocking up a cad model for a uni project, i have the book, but cant find any
dimensions, it just says use the ball joints to mark them out.
Just need the size of the bolt holes and the size of the hole the joint sits in on the wishbone. If i was at home i would go and measure mine, but
being at uni its a bit of a trek!
Chris
The Magnificent 7!
Mix
posted on 27/2/04 at 09:59 AM |
Large holes = clearance for 12mm bolt
Small holes = clearance for 8mm bolt
Clearance for ball joint = 50mm
Angle of bend = 159 degrees.
I'll be impressed if you can complete your work with just those dimensions though
Mick
greggors84
posted on 29/2/04 at 10:37 PM |
Its just a rough model, its all about the suspension really, will do me till i can get home and get some more dimensions off my car.
Thanks alot.
Chris
The Magnificent 7!
