amalyos
posted on 1/5/09 at 04:09 PM |
Metal in R1 5JJ Sump
Following my breakdown and the repetitive knocking noise in time with the revs, I've checked:
The compression (only cold), but all cylinders are equal.
The valve clearances, all ok.
Then I took the sump off and found lot of slivers of metal. All bits are around 0.25mm thick, ranging in size up to around 10mm square
They look like bits of a shim.
Any one got any Ideas???
![](/galpreviews/a937937-IMG_1794.jpg) ![Rescued attachment IMG_1794.jpg](/gallery/a937937-IMG_1794.jpg) Rescued attachment IMG_1794.jpg
http://stevembuild.blogspot.com
richardh
posted on 1/5/09 at 04:12 PM |
oh kak, sorry to hear that.
hope its not too bad for you
Time for a change!
posted on 1/5/09 at 04:13 PM |
Looks like big end bearing shells to me
Phil
[Edited on 1-5-09 by Hellfire]
stevec
posted on 1/5/09 at 04:14 PM |
Bearing shells probably.![](/images//smilies/sad.gif)
smart51
posted on 1/5/09 at 04:39 PM |
When the big ends went on my old 4XV engine, the oil had tiny flakes of copper in it. less than a millimetre in area and a tiny fraction thick. Your
failure looks all together different. When I first saw the black fragments in your picture I thought it was gasket material. from memory, the sump
gasket has a big area on it to act like a baffle.
Guinness
posted on 1/5/09 at 05:08 PM |
When my big end went, the oil that came out was really metallic.
The bits of bearing itself were spun from the semi-circular bearings, so they were all curved round, if that makes any sense.
Now you have the sump off, can you have a look into the engine from below? Give everything a good shake and see if anything is loose. When the big
end went on mine, you could physically move the conrod on the crank shaft.
Hope it's not terminal.
Mike
dean100yz
posted on 1/5/09 at 06:42 PM |
Mike
Ive had a few MX bikes go and 1 road bike do the same too. When the big ends went the oil had got a silver look to it. the metal was very fine. What
you have looks quite big.
My road bike, a benelli had pieces that size which turned out being the gears from behind the clutch basket (they come with a slipper clutch).
Pics to show:
It just looks too big to be big end imho
amalyos
posted on 1/5/09 at 08:19 PM |
Cheers everyone, I think it is the big ends, turning it by hand, I've noticed a tight spot, and can just make out some jagged edges sticking
out.
Anyone know a good engine builder for a rebuild?
stuart_g
posted on 1/5/09 at 08:33 PM |
Speak to Andy Bates (AB Performance) about the rebuild he will be at the show on the Raw stand, maybe worth taking your engine to Stoneleigh and
asking if he can cast an eye over it for you.
[Edited on 1/5/09 by stuart_g]
amalyos
posted on 1/5/09 at 08:58 PM |
Thanks Stuart.
George and I are going up on Sunday, are you planning to go?
GregSL75
posted on 1/5/09 at 09:38 PM |
Big ends have just gone on my XE and the slivers stuck in the sump and pump strainer look quite similar to that. Razor sharp and super thin.
2.0 XE on GSXR TBs and Megasquirt
stuart_g
posted on 1/5/09 at 10:47 PM |
quote: Originally posted by amalyos
Thanks Stuart.
I will be there on Sunday![](/images//smilies/smile.gif) See you there.
cosmick
posted on 2/5/09 at 05:56 AM |
That is definately the remains of your big end shells caused by a loss of oil pressure. you will need a minimum of a new crank and possibly some
conrods if you intend to rebuild this engine.
amalyos
posted on 7/5/09 at 08:20 PM |
Got confirmation today that my R1 is officially dead
Crank journals scored and rods gone.
Too expensive to repair, unless anyone has a good set of rods and Crank !!!
On the look out for a good carb'd 5JJ or may have to plunge for an injection.
If anyone knows of one please drop me a line.
Thanks to George for dropping the Engine into AB's and thanks to Andy for looking at it.
easisatman
posted on 7/5/09 at 10:04 PM |
Sorry to hear that -had you done a lot of miles or to many high revs and missed gear changes. well good luck
hope you get it sorted soon
Paul
Minicooper
posted on 7/5/09 at 10:26 PM |
I have a 98 R1 motor if that's anygood I believe the rods/crank are perfect but wouldn't be able to confirm that until the motor was
pulled apart £120 for the lot, if you need things like the oil pump, etc will throw that in aswell for nowt
