Northy
| posted on 27/2/04 at 09:02 PM |
Location of fuel pressure regulator?
Hi, just been out to the garage. 'tis bloody cold!
Anyway, can anyone see any problems with running the fuel line round the engine bay (carbs side, not exhaust) to the front, and mounting my fuel
pressure regulator (filter king) at the front? Ideally I'd like it infront of the drivers footwell, but things are getting very cramped
there!
Any problems with it being in a cold air stream?
Graham
skippad
| posted on 28/2/04 at 09:04 PM |
Hi Northy
I've fitted my Filter King near carbs attached to drivers bulkhead.
Its cool there but not too cool and easy to clean filter when needed. Its there OK for over 3000mls
Skippa D
Dave Ashurst
| posted on 29/2/04 at 08:03 AM |
Hi Northy,
I don't think it should be a problem (given a sufficiently rated pump and pipe diameter of course). If you only have space there I'd give
it a go. After all the fuel's not going to freeze is it!
The space was cramped in mine too, but because I added the regulator into the existing pipeline I still mounted it near the bulkhead. I put it on a
small cranked bracket. Sort of up and over the pipework etc.
Mine is the type without the filter bowl though, so it was slim enough to do that easily.
regards
Dave
Northy
| posted on 29/2/04 at 08:57 AM |
Cheers guys, I'll have a play today once I've finished the brake lines and see how much room I've got left
At last, something that might be straightforward..........
Graham
