Author: Subject: brake stuff, where from?
Miks15
posted on 6/5/09 at 05:08 PM Reply With Quote
Hi all,
I want to start on my brake lines pretty soon, but dont know where to look to get parts!
I need all the piping and unions etc.
First thing is what do i need? how much do i need? and wheres the best place to get it from.
IM using a Sierra master cylinder so i need the right unions to go into this.
I also need some of the plug things that go in to the top of the sierra MC and some hose to go upto my resevoir. (im using the original BMW resevoir as it already has a third hose off it for the clutch.
Mikkel
theconrodkid
posted on 6/5/09 at 05:15 PM Reply With Quote
have you got a tool to put the flares on?
i used about 1 and a bit rolls of pipe on mine,available at most car type places.
i just changed my master and am going remote reservoir,i couldn't find the "spouts"(fitted to fiat 124/127/128 ) that go into the master so am having some made.
ive got the part numbers if your feeling lucky
who cares who wins
pass the pork pies
Miks15
posted on 6/5/09 at 05:30 PM Reply With Quote
I do have a tool to put flares on.
Is there any difference in pipes? or is it all a standard size?
Do you know what size unions i need to go in the sierra MC?
D you have any dimensions of the spouts to go in the MC?
theconrodkid
posted on 6/5/09 at 05:47 PM Reply With Quote
pipes are 3/16",10X1 is standard unions and 12X1 for the master,u2u me yr e mail addy and ill send you dims of the spouts
who cares who wins
pass the pork pies
pewe
posted on 6/5/09 at 06:29 PM Reply With Quote
As far as suppliers go I used Rally Design and BGC Motorsport. Later is always helpful and despatches quickly. Pipe bender from Machine Mart
Pipe for main runs is best in Kunifer (copper/nickel - slightly harder to bend than copper but more durable) but make sure it's marked as brake pipe. Lots of P clips to attach to the bodywork.
I used silicone fluid as it has a higher boiling point but you can't (as far as I know) mix and match it with components that have used ordinary mineral fluid.
HTH, Pewe
