RMarine
| posted on 6/5/09 at 09:13 PM |
removing diff drain plug
i need to remove my diff drain plug, but its stuck. any ideas???
Jasongray5
| posted on 6/5/09 at 09:14 PM |
Impact wrench
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
RMarine
| posted on 6/5/09 at 09:15 PM |
i have treid that but it's starting to strip it
owelly
| posted on 6/5/09 at 09:17 PM |
Take the fill plug out and suck the oil out through there.
http://www.ppcmag.co.uk
We used a breaker bar on ours but unfortunately we cracked the diff casing around the plug in doing so and had to get it welded up. The drain plug did
come out but I wouldn't recommend it. Impact wrench may be better.
Phil
Jasongray5
| posted on 6/5/09 at 09:18 PM |
Weld a nut onto the end of it, the heat will help loosen it and your wrench will have summat decent to grip?
How hard can it be?
mark chandler
| posted on 6/5/09 at 09:19 PM |
Same for mine so I drilled a small hole next to it and tapped this while the oil was still dribbling out washing the swarf away.
Matching bolt with a bit of sump seal to close.
Manufacturers do not change this oil often if at all, so I do not expect to ever refill mine.
RMarine
| posted on 6/5/09 at 09:20 PM |
LOL
Paul (Notts)
| posted on 6/5/09 at 09:25 PM |
If its not fitted to the car then just remove the back plate .
refill with the correct amount of oil
drain plugs are a nightmare to remove and new owns are difficult to get hold of.
Paul
RMarine
| posted on 6/5/09 at 09:27 PM |
thats what i'll do, how much oil is needed?
Howlor
| posted on 7/5/09 at 07:40 AM |
Thats what I would do. Will work for sure.
