Author: Subject: NEED wheels with NEGATIVE? offset
marcjagman
posted on 2/8/02 at 08:33 AM Reply With Quote
I need some wheels with a negative? offset as my axle is a little narrow so I need some wheels that will stick out a little they are Vauxhall fitment (100mmPCD) so many others will fit just which ones stick out the most, thought about axle spacers but need about 14mm each side to be able to accomadate trailing arm mounts.
