Miks15
| posted on 17/5/09 at 11:30 AM |
split steering shaft bearing
My steering shaft is in 2 pieces so i need a bearing to hold one part in place.
What kind of bearing do i need? Does it need grub screws to hold the shaft in place of is a push fit enough?
its 14mm diameter shaft
mikkel
MikeR
| posted on 17/5/09 at 11:46 AM |
I used an anti roll bar bush. Holds it in place nicely (although i've not been through IVA with it).
stevegough
| posted on 17/5/09 at 01:57 PM |
try again. (i've been searching for the link I needed) but the site closes the reply box when you hunt around!
Anyway - there was quite a discussion on this about a month ago - the title was...[ Fitted a lower bearing to a Sierra column in a Locost ] -
admittedly not exactly what you are asking, but the bearing about 11 of us ended up buying was this one:
http://simplybearings.co.uk/shop/p22810/SBPFL205+Oval+2+Bolt+Pressed+Steel+Bearing+Housing+with+25mm+insert/product_info.html
nice bit of kit and quick delivery too.
HTH, Steve.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
mad-butcher
| posted on 18/5/09 at 07:40 AM |
and amazing how free it makes the steering column, defo a top tip
tony
