Author: Subject: Brake lines
jeffw
posted on 19/5/09 at 05:31 AM Reply With Quote
Brake lines
Morning
Just bought a set of Wilwood calipers from a very nice person on here Need to fit them to a Phoenix which has M16 brakes currently. The pipework to the M16 has a flexible armoured hose from a connector on the chassis which connects to a rigid line on the upright and then into the caliper. The car uses Escort uprights
Does anyone know what length and fittings I need in a flexibable hose to to connect from the chassis to the Wilwood calipers ? I assume it is best to replace the rigid section on the M16 with a flexible hose ?
And the next question would where to get the hose from
iank
posted on 19/5/09 at 07:36 AM Reply With Quote
Originally posted by jeffw
Morning
Russbost of this parish sells very nice hoses with whatever fittings, length and colour you need/want.
I'm sure he'll also be able to advise on which fittings you need.
http://www.furorecars.co.uk/
[Edited on 19/5/09 by iank]
Anonymous
posted on 19/5/09 at 08:02 AM Reply With Quote
Morning
NTDWM, but you'll get excellent advice and service from Russ, an A1 supplier!
