Author: Subject: Is this suspension mounting ok?
200mph
posted on 24/5/09 at 11:42 AM Reply With Quote
Please see attached pic - I've only seen pretty vertical rear suspension units so was after thoughts on whether this is ok?
Mark
[Edited on 24/5/09 by 200mph]
If it isn't broke, fix it until it is
MautoK
posted on 24/5/09 at 11:46 AM Reply With Quote
Can't really see much detail in the little pic...
blakep82
posted on 24/5/09 at 11:47 AM Reply With Quote
they look vertical to me. can't really see from the photo.
heres mine though,
seemed ok for race cars, and your front suspension isn't verticle either, so won't be a problem
________________________
200mph
Sorry, just noticed I selected wrong pic. Changed now though.
Mark
MautoK
posted on 24/5/09 at 12:07 PM Reply With Quote
Is the bottom end of the damper supported on both sides?
If not, the bolts supporting it and the panhard rod look to be vulnerable to bending moments and potential fatigue failure at some point in the future...
John.
200mph
posted on 24/5/09 at 12:26 PM Reply With Quote
I can't tell 100% from the picture, even on full size but it looks so.
It's something I'll look for when I go see it - it's a prospective buy at the moment.
big_wasa
posted on 24/5/09 at 01:31 PM Reply With Quote
lots of locosts are done that way. Mine is. But I am not saying its the best way of dooing it either. I know it will be subject to bending moments. But mine are 1/2" Ht bolts.
That would need a lot of force to bend with a 50mm of leverage in a 500kg car ?
The wheel of a car is only supported one side.
blakep82
posted on 24/5/09 at 01:41 PM Reply With Quote
true but with at least 4x more bolts
but yeah, i really don't think it's a problem. as long as the top shock bolt goes the same way as the bottom one, ie side to side
posted on 24/5/09 at 02:06 PM Reply With Quote
Not just Locosts either, many production cars have suspension mountings in single shear, but the fasteners must be appropriately sized.
blakep82
posted on 24/5/09 at 03:26 PM Reply With Quote
my dads ford aerostar van was the same on the shocks actually. seperate springs though, so i think that makes a difference
MikeR
posted on 24/5/09 at 10:42 PM Reply With Quote
I'm about to do exactly the same as you.
(for different reasons).
Got the shock in double sheer so i'm happy it will be ok.
